Hey guys. I'm so sorry for the absence. I've just been very busy and overwhelmed; I'm at work or on writing projects 6 days/week. I'm still here and so is the bike! I kept waiting to post till I had more info to give and then kept waiting around for the best time and until I delved into the next thing, but as many of us know rationally, there is no such thing as the best or perfect time. So, real quick before I have to go to work: valves are done, cam chain is adjusted, new choke cabe in (and working), pushrod seal leak fixed (again), gasket on side oil cover swapped; bearings are okay.
That's a good amount of things and I'd love to take credit for all of it, but alas, I can't. I'm bummed to say it, but I had to pay someone to do the above because on top of the weird cut out it gave me, I didn't have time to do and keep up with it all and I only have the street to work on now etc etc.
That said, pushrod seal or something else may be leaking again becuase, while it was fine for a bit, oil is running down the side stand again. Also seeing oil run down oil filter cover on side case again so maybe that gasket wasn't swapped--or wasn't done well. I want to take another look at the bearings too cuz I felt something the other day. Oh and oil drain plug washers swapped.
I'm out of time right now, but the next step is to see if I need to change my tires considering the roads out here. I want to see if the wobble I got on the highway out here was the loose bearings plus the tire tread, or just the tire tread. Now that bearings are okay I'm gonna risk another shot. After that, it's back to making sure those leaks are actually solved.
As for the life of this thread: while I am absolutely not giving up on this bike, there will be long pauses because I just don't have time to work on this every week and I'm currently wrestling with the fact that I may have to hire someone to do some of the modifications I want becuase otherwise they may not happen--if I could even afford it. So, if the pauses mean you guys would rather me wrap up or delete this thread and just start a new one when I have an issue, let me know and I'll do it. Otherwise, I'd love to keep it alive so I can pop in when I can. I just don't want to oversell my availability. (Clearly I was hoping I could magically do this all before certain life demands came back but didn't quite make it)
Wrote this out fast as hell but hopefully it makes sense
