DavidIsaak
Good day All,
I know what you're thinking- "oh geez, another I fouled spark plug story that could have been easily remedied by using the 'search' button". Please, I ask for your mercy as I explain myself
I have searched and favorite'ed and re-read and seem to be stuck. But I have a feeling there is an easy remedy that my fellow XS650'ers can help point me in the right direction.
Location: Calgary, AB. Elevation: 1100m (3630 ft) above sea level
The Bike:
1981 XS650SH (Canadian Model sold by Yamaha in Winterpeg so says my gas cap)
Uni Pod Filters (freshly cleaned and oiled)
XS650 Direct (Mikes XS) 2-1 headers into a cone muffler
BS34 Carbs - Left As-is adjustment wise. Cleaning only
132.5 Main
42.5 Pilot
On/off Petcock (new this year)
Carb rebuild kit from Mikes. Also followed the excellent carb guide when cleaning. Thanks guys!!
Ensured plastic floats were set correctly along with cam chain tension and valve clearances to stock 1981 specs.
New high output coil, high tension wires, 5k caps and NGK BP7ES plugs gapped to .030"
Fuel/mix screw set at 3 turns out, then 1 turn out, then 3/4 turns out, etc. Doesn't seem to make a difference.
Lithium Ion Battery that is in good working condition.
Bike has E-start (new controls this year) and safety relays removed and jumpered. Although I try to kick it over often to save on E-start power.
Hopefully that is enough background to help diagnose my issue.
For as long as I remember owning this bike I keep fouling my plugs. Black and sooty, not oily, telling me it is fuel related. I thought maybe the ignition system was old and tired not allowing a nice clean spark to burn the fuel so I replaced it and also figured out Autolite 63 plugs with resistor caps was not helping (duh), so I ordered the stock BP7ES plugs with the new coil, wires and cap which I thought might have solved the problem. Alas, the plugs seem to be fouling even on both sides within 100 km resulting in a poorly running, barely idling bike. So with the reading I have done and advice I have sought, this tells me my pilot jet is set to too rich perhaps? Would altitude have something to do with this even with the increased airflow (or maybe not) with the pod filters and free flowing exhaust?
When I replace the plugs with brand new, the bike runs really nice and pulls really well through the entire RPM range, but it doesn't take long for it to start to stumble and sputter and not idle nice, making for a short outing.
So yesterday, I was checking other things over and decided to follow the Haynes manual in also checking my alternator and rec/reg to ensure my battery is getting sufficiently charged while riding. It appears *edited* the resistance between slip rings is only 2.1 ohms and the brushes should be replaced as they were only 8 mm long (just under 3/8"). When testing my rec/reg for continuity it did NOT pass on the first diode so I will be doing the Fiat regulator and 3 phase rectifier mod once I receive the parts. Would there be an off chance this could be causing some issues? Also, I have no reason to believe my TCI box is a culprit either (read about that this morning). I should also mention that I have cleaned my connectors with contact cleaner and used dielectric grease when reconnecting.
***EDIT*** : Rotor resistance across the slip rings is 2.0 Ohms. Rectifier and Regulator are OK based tests from the Haynes manual. 13.3 V at 1500 RPM and 13.8 at 2500 RPM. Brushes require replacement.
If you have made it this far, I thank you for taking the time to read my sob story and really appreciate any helpful advice you can offer up. It really has been a fun puzzle to figure out. Let me know if I have left anything important out that might help.
Thanks,
David
The Bike:
132.5 Main
42.5 Pilot
Thanks,
David
