Eric12171
Hi again,
I have another question about my ignition
79 special, stock ignition , points etc.
It started having a slight cutout on me when I was riding,
Now it’s worse,
It was sitting at idle and it would just cut out occasionally like 1cylinder wasn’t firing.
Then it got worse to where it will start when cold then dies out once it gets slightly warm.
Now it wont start at all .
So far tested :
Battery 12.9
Both coils 4.0 ohms
Coils to plug cap , I had to redo some things ,
Had 1 hitting 23 or so
Now they are both at 14ohm
Grounds are good,
Points are set and timed
Checked the spark with my plug checker
Right one gets a good spark occasionally.
Left barely anything.
I’m left with guessing the condenser is bad ?
It’s maybe 6 months old along with the points and less than 1000 miles.
Thanks in advance
Now it’s worse,
So far tested :
Battery 12.9
Both coils 4.0 ohms
Grounds are good,
Thanks in advance
