I got the pwk flat slides from mikes xs running like a dream. I live in eastern Ohio, running stock exhaust, vape pma and electronic ignition and velocity stacks…. these are a must for excellent performance out of these carbs.
To set float height:
I drilled a hole into a tapered rubber stopper, shoved a clear tube into the hole and filled the carb with fuel via the fuel inlet, hold the open end up to the side of the carb and the bottom of the meniscus should be about 3/32” from the mating surfaces of the float bowl and carb body.
I’m running a 40 pilot and a 110 main that came with the kit, needle clip is set 3rd notch from top, and air screws are adjusted until you can see about a 5/16” of space under the slide.
During summer I can run the fuel screw at about 2 1/4 turns out from bottoming, at temps around 40 degrees that screw can go in anywhere from 1 to 2 turns out.
Had this setup for a year and a half, had to clean the carbs once and I ride a lot. After cleaning still No weird noises at all, instant power no matter what gear or where you are on the throttle, seems to always have more to give. I don’t think fuel injection would even run or sound this good. Hope you have luck, don’t give up, they’re definitely frustrating at first but so worth every bit of frustration
