Anybody recognize this cam?
View attachment 164847 ... The height of the lobe is 1.52” the base is 1.20” ...
Sounds like a regrind.
447 specs.
Shell #1 specs.
On that lift plot, each horizontal gridline is 0.010"...
Amazingly, I timed the megacycle 250-40 cam I have up this year, and my unrecognised cam outperforms it , I am about 5mph down and at least 0.25 seconds over the quarter, whilst the timing can be what happens on the day, terminal speed is normally a constant unless I really stuff it up.
The 250-40 is retarded by 4 degrees as everyone says is better, the unrecognised cam just gets put in on the timing marks as there is no data to go by.
Just managed to measure the cam
Inlet 22 btdc 64 abdc 0.430 lift
Exhaust 60 Bbdc 45 atdc 0.400 lift
Any clues on this cam?
Just bought a shell #3 cam and got the timing information for it from Gary Hoos the duration on the exhaust is virtually the same as my cam even the opening and closing times
Keep going back to using this cam, must have always had the crankshaft in a different position as it took me bt surpise being able to see straight through the engine
