desmoman900
650 Society Director
Not damaged enough to make any significant noise.I’m thinking that really sounded like a bearing going out. Possibly the worn cam bearing you mentioned?
I’ve done the spinning test on all bearings and, aside from a rough cam bearing, all checked ok. Inner crank bearings are easy to inspect just by sliding the races out.It is an obvious investigation to do .spinning and listening .feeling if it sticks and so
I have had them wear out .
One can Cut open with an angle grinder look. Since it wont be used anyways.
The crank can be difficult to check .It can spin fine a while and then stick at other
Rattle coming and going
Any idea where the sound came from ?
Regretably no. I trusted Marty’s judgment and I didn’t want to aggravate the issue.Videos lie but that one marty made sure made it sound like the RH exhaust valve area.
João: Did you run this motor to hear the noise before the tear down?
Which bearing are you proposing to cut open?
Keep in mind that this is a 14k miles engine.
I had a FaceTime with João (I can type it, just can't say it) at #Tempio della Velocità. He showed me the #4 starter gear. It looks great.What is the condition of the #4 starter gear?
The question becomes "Where did this come from?" I changed the oil before departure. That screen was clean. There was likely not more than 200 miles on the oil. I had vibration to go with the noise. The bearings all look good.
Those bits ferrous or aluminum?
Metal shards, steel or aluminum?
clutch cushion springs checked?
I only felt it riding it and the vibration came and went. It was intermittent. I had to ride a bunch of miles to get a truck and I was very concerned about wrecking the engine.Vibration makes me stuck at crank bearing .excessive play. Was there Vibration on standstill also or driving only
