180 mains? What carb?
Mikuni vm34s
I did pick up a second set of rims to mount some street tires to and do an easy swap.
I plan to mainly ride in beach sand with this ( the reason for the knobs). An it’s small one lane back county roads to the beach.
If I want to go for a long ride, I’ll swap wheels.
Thanks for confirming that knobs are terrible on road. Atleast I know I’m not crazy haha.
I run Pirelli Scorpion MT which are a block tread. They are good on road in the dry. And offer decent traction in the loose. Can’t comment on mileage as it’s a Sunny Sunday ride.Soo absolutely no response from niche cycles about the bent kick start. Multiple emails sent.
I’ll try and track down an original.
As for the bike itself goes… gurgles off the line… backfires on deceleration.
My current jetting
180 main
6f9 needle
20 pilot
2.5 slide
159 p6 needle jet
- it seems rich down below and lean up top. I havnt ridden it enough to get a good color off the line so what I think is a gurgle from being rich, it may be lean down low as well.
I’ve ordered some 190 mains so I’ll see if that helps. I’ll first drop my needle a slot and see if it improves the take off, if not I’ll raise it. See what each does for me.
Beyond that it seems like quite a solid set up.
- on a side note, anyone ever run knobbys on the street. They seem a bit “trackie” as they have quite a soft square edge. Done really roll over like a street tire. Quite an upright ride. - I have had em through the back field at my place(pretty much loose sand) and they handle quite well.
My TX650A has Bridgestone Trailwing TW42 rear and whatever the matching front is. I bought the bike this way almost 3 years ago and am looking forward to changing them to a street tire. They were new when I got it so I didn't change them. Really LOUD after about 50 mph.
How do you like that dr??Indeed they are. I had them new on my DR650 and they were pretty lousy. I upgraded to a Dunlop D606 on the rear and kept the front, now about to change them out to Shinko 805/804, like a Kenda big block.
As a general rule, no. That's why racing engines have large open pipes...Didn’t know if that was typical with a larger wide open pipe.
