Gents, my bike died on me today I've recently installed the elec advance unit and timed it and it was running fine then I fueled up with premium unleaded 98RON and barely got 2kms away and it started backfiring and died. I didn't have any tools available and a good Samaritan happened to pass by and offered to take it to his shop and despite having done all the work on it to date myself I relinquished and let him take it. I did manage to kick it over once more but it burbled and spat and backfired something terrible and then died after about a minute. I'm leaning towards some type of fuel delivery issue. I recently replaced the fuel hose because I believed that the original was kinking and choking the flow. I have the inline paper filter and stock vacuum petcock and even when on prime it isn't flowing into the filter which made me think perhaps the petcock filter was blocked but if I take the hose off it flows out freely and when running it does trickle fuel into the filter. I normally run regular unleaded which is 95RON but wouldn't have thought the slightly higher octane fuel would've put the bike out to cause this issue.
Summary of status of bike and work done by me:
81 special with original tank and petcock that haven't been serviced to my knowledge
150psi in both cylinders when checked last
Hugh's PMA
Pamco ignition and adv. with high output coil
650 central BS34 carb jetting kit -
Enlaged slide dampening hole
Titanium needle with clip in #3
#135 main jet
#45 pilot
Float checked and in spec
low speed mix screw at 2.5turns out
pod filters (http://www.mikesxs.net/product/15-0033.html) (I know I should replace these)
Rewired and running a 32k Mu capacitor
Original petcock not rebuilt.
Jama Mufflers which do have a bit of a leak where they join the headers.
I appreciate any assistance or suggestions that help. The mechanic is a local mod shop that generously helped out today - big shout to dockyard dragsters in mayfield (newcastle, NSW Australia). The owner offered to trailer it to my house and refused payment which I will now have the opportunity to pay him back for. I'm confident he'd sort it but having set the bike up myself I'm curious what the problem could be. I'd troubleshoot it myself but unfortunately I'm working away from home all year so time working on the bike is better spent riding it and I've not done much of that
cheers.
Hugh's PMA
#135 main jet
#45 pilot
cheers.
