Hazmat6666
New to the XS world
He all, hoping for a little direction.
72 xs2, open pipes, mikuni vm34s (brand new, working to dial them in), with air pods, electronic ignition.
I just put on a set of Mikunis from Niche Cycle replacing the old falling apart (damaged) stock carbs. With the "choke" in, it starts easily, will run on the choke, I have been able to ride it and let off the choke, good acceleration in all areas, low, mid and full throttle.
When I come to a stop it will idle for a short bit, maybe 10 to 20 seconds, then as best I can describe it, it 'ticks' almost like a small backfire or detonation. It will do this for a few seconds, then the idle will all of a sudden slow down and puke out. Also of note, I adjusted my timing chain and valves yesterday (.003 in, .005 ex)
Once this happens I can restart, but I need to use the choke, even though it is well warmed up. If I give it a little throttle blip I can keep it going but would like to be able to stop at a light without fear that I am going to have to kick it over (oh yeah, kick only).
