BMW R1200GS The Great Adventure
Another option, Adam....
Instead of paint which is more or less permanent, find something like the thick black (grey?) foam. Cut that into little blocks you can compress and stuff down into the little squares the LED's are in. That'll block 'em as good as paint... and be easily reversible should you decide to.
“Only I will fit black foam into the light ports” from my post 77
Cheers Jim, great minds think alike!
CASTRATION OF THE BRATS ABS!
Like alot of us life gets in the way of pleasure; with work, wife, and chores taking precedent over bike time.
I started the removal of the ABS system about three weeks ago, but could only find short time slots to get to the workshop and complete the job. My shop is three miles from my home so I have to plan things in advance; not just a quick drop into the garage next door so to speak.
After removing the seat, bodywork and fuel tank (simple) I disconected the battery.
The associated ABS pipework was removed, leaving the 'normal' brake lines in place.
Various Torx bolts (difficult access) were removed, and the ECU diconected, to allow the ABS pump and attached ECU to be lifted from its cradle.
ABS unit moved to the bench for removal of the ECU.
The pump alone weight is 4.4Kg, with pipes that must be around 5.0Kg. This weight is carried quite high up on the bike.
Next job was to remove the ECU from the pump which is held on with..........
Four 5 point security Torx bolts! I have every 6 point Torx driver known to man; but this is a BMW/ECU makers creation.
In the end I carefully drilled out the little blighters.
Disconect the enclosed wires, all are push/pull fittings.
Tidy up the wires and contain the tails inside the ECU box.
Finally seal up the ECU with some RTV and the supplied replacement rear cover from BMW Motorworks UK.
I returned the ECU back to the bike secured with Zip tires on rubber mounts, and reconnected the Bike loom to it.
Then its back to the brake lines. All fairly straighforward to adapt with the supplied links from Motorworks UK.
Front link installed in image above.
Brakes were then bled and retuned a good firm lever and pedal.
Next job was to eliminate the constant warning lights on the dash clocks.
To remove the clocks you have to take the front screen off; plus any Sat-Nav kit you have attached.
This allows better (still shitty) access to the retaining clips that hold the clocks onto three nipples.
The bikes brain is still looking for ABS information not realising its bits have been cut off!
Some YouTubers just tape over the two flashing lights.
Others remove the clocks and open them up to apply black paint over the LED's as seen below
I chose to cut sqaures from black foam sheet and insert them into the ports where the LED's sit.
Replece the cover and refit the clocks for a more factory appearance.
The lights still flash beneath the foam but cannot be seen by the rider.
Reinstall the tank and connect any remaining err... connectors; and refit the fuel lines.
Another visual check over and then a test which threw up a few faults.
1. The rear brake light was now constantly on.
2. Iggy on and press start = Cranking but No Fire.
The rear light issue was traced to the front brake micro switch. I didn't touch the brake levers but it took a full hour to reset the switch, and become operational again. Crank - Nostart seems to have been cured by disconnecting the battery for a system 're-boot' and cleaning all electrical connections carefully. Also the fuel lines can upset the system if they are not fully seated home in thier 'quick-release' connections.
The brat now starts up again and all seems to be working. I will make a test run after fully servicing the bike with fresh oil / plugs / filters etc next weekend..... Weather permitting.
THE BRAT = FRUSTRATION!
At last its a sunny Sunday
So with the ABS system removed and a final clean and tidy up.
The brat got a full service with new fresh Castrol oil and genuine BMW filters.
Checked the sparkplugs and tire pressures.
Time for a test ride.
Key in and switch on, press start and........ A slow crank is the result.
Check battery voltage and its showing 5.5Volts; Crap!
Connect charger to The Brat battery, and Get Taffy out for some work.
Two hours later and The Brat battery is showing no improvement; time for a new battery me thinks.
Time for the pub too........
BRAT BAT
Ordered yesterday from TAYNA UK at 13.00hrs (I have used them before and they offer great service)
Arrived today at 13.00hrs.... Yippie!
Motobatt are a well respected maker; not the cheapest I could find (£35.00) but not the most either (£136.00).
Cost with shipping was £83.00. Good specs as you can see with 240 cold crank amps and 16.5 A/h.
Another good feature are the four corner binding posts to ease fitting; complete with various connection pieces and bolts.
It was supposed to be fully charged for immediate installation; but measured at 10.5 volts :(, so I have connected my tender as you can see.
Hopefully a fitting tomorrow and test.
Ads.
When you hit a dead end it's always time for a cold one at the pub
Support your local business
Always wanted to try one of those Bimmers, I never really could afford one so I settled for the poor mans version the Suzuki DL1000 V-Strom. I enjoyed it for a while but found myself riding my Road King and Suzuki DR-650 in their respective environments far more so I sold it.
Still curious about that BMW though.... :bike:
Bimmer = automobile Beamer = Motorcycle
The Brat Gets a Motobatt.
Mrc C was in a good mood today, to be fair she normally is, and suggested me having some workshop time whilst she went to the nearby retail park.
I tested the old battery again and it was down to 5.3Volts, so it ain't holding charge at all, indeed its losing spark power continually.
New fully charged battery installed and press start. Engine turns over with solid intent but alas no fire.
It seems the pump module is playing up; another known fault on these machines.
Side panel off again; unplug the petrol pump module, clean contacts, reinstall plugs and....... Bike fires up straight away :D.
Run bike up to operating temps then turn off to inspect oil level since the service (not church) on Sunday.
Sight glass shows it needs another 200ml which it gets. Fire up again without issue, run a few minutes and then turn off and settle the oil.
Check level again and its spot on.
As the weather is very mild and roads are dry, time for a test run.
A few laps of the estate and the brakes are tested by some gentle stops, and then some full on stops.
Happy to say the power of the brakes do not seem to be affected by the loss of the ABS system; in fact the front end feel is better and more controllable at extremely hard stops (No ABS pulsing). The rear brake seems to be stronger too. Dry conditions today of course; in the wet I may miss the ABS, but as an advanced rider I should be able to ride to the prevailing conditions.
I could wire up a bypass for the pump module, powered from the auxiliary socket, as a get me home if it fails; but it's more likely I will buy a new module anyhow. Overall Im happy with the deletion of the ABS, and that The Brat seems even better on the road,
Ads.
Some of you have been following my adventure with my Welsh Flat Tracker below:
After a total rebuild and rewire I'm still sorting out a running issue.
Gonzo Box now installed and yet to be road tested.
On Purchase Mrs C was unhappy with the lack of a pillion seat.......
So I took charge of a mates Bandit 1200:
It needs work and now an MOT; but he won't sell it to me.
He hasn't been on the road since 2013! What a waste.
I have used it and like it; strong engine too.
Yesterday a bike popped up on eBay which sparked my interest.
A phone call to the owner proved fruitful and all details checked out.
With my wife's pillion needs in mind (although not discussed with her) I negotiated a fair price and pulled the trigger on........
This Concourse minter of a bike:
A BMW R1200GS 2005 Just two owners and only 7500 miles.
So I paid a deposit via my mobile unknown to Mrs C. Arranged insurance; and collection by my delivery team for next week.
Feeling a little guilty and excited all at once; and wondering how to break the news to my wife.
Little did I know that whilst I sorted out the payments she was using my iPad at home and monitoring the whole process! Yikes!!
I arrived home to a rather cool reception whilst Miss Marple (Mrs C) extracted my guilty pleasure rather painfully for me.
After an hour of squirming she actually gave way and was OK with the whole shebang.
If anyone's interested I'll run a thread on this bike.
What a marvelous wife I have.
Ads.:bike:
Nice Beemer indeed, one word of caution with this year, they have servo assisted ABS brakes which BMW dropped by 2007-2008. The pump itself if not regularly serviced will give trouble, not if but when,
Like anything BMW they cost a fortune to replace, most owners fit a bypass kit and remove the pump altogether and do without ABS…I’m sure with yours having low mileage it shouldn’t be an issue yet but worth researching online.. when they fail you basically have no brakes.. scary to say the least.
Thanks for the heads up; but you need to read this thread as I documented the removal of the ABS system. 👍
THE BRAT - Fuel Control Module.
So after removal of the ABS system and upgrading the battery as told above; the bike was still playing up on start up.
The bugger would turn over fine but no fire up. If I disconected the battery and unplugged the Fuel Control Module, then reconnect, it would fire up no problem. Turn off and try to restart no fire in the hole!. I suspected the Fuel Control Module (FCM) as it is a notorious failure part. BMW want £140.00 for a new one! ALIExpress have YingYang knock offs for £35.00. So I went to my usual supplier BMW Motorwoks UK and bought one for £85.00; at least I can send it back if its shite.
The new item came and the only obvious difference was it was powder coated black, not the bare ally casting of the origonal one. Disconect the wire leads, two plugs; unscrew two T20 Torx and ease out of the fuel pump housing.
The new black unit was a straight swap and it took all of 5 minuets to complete.
Bike fired up instantly on first and subsequent tries.
WHO SAID DONT GET FOOLED AGAIN!
As a belt and braces measure I decided to make a 'Get Me Home' emergancy lead in case the new unit fails down the line. Reading the wiring diagram the main plug has a power supply (2), earth (3) and a wire that goes to the ECU to control the fuel supply monitor (1).
Only 2 & 3 Will be used in this application.
Its a simple process to disassemble the module by removing all the silicone 'potting' material off the back side; then carefully cutting around the edge to lift the PCB board. The entire underside is cocooned in silicone also, no wonder they fail through over heating? Clean off all the silicone stuff. Isolate the main plug connector and cut away from the PCB board. Then cut off the blue & yellow leads.
Next process is to solder the Blue & Yellow wires to the socket connectors.
Protect the exposed solder points with insulation tape. Wrap the whole lot with some TESA Tape.
Finally I give it some weather protection with a bit of black heat shrink wrap.
The above should offer a quick way to get me home in an emergency. As this 'trick' is by-passing the ECU control, the fuel pump will run constantly rather than 'on demand' of the bikes brain. The link wire is kept under the fuel pump cover together with a cut down T20 Torx key to facilitate a simple swap.
Jobs a good 'un.
THE BRAT GETS A REFRESH
A little time down at the workshop yesterday.
First was to give The Brat a full oil and filters service, which went realitively easily.
A small error when refilling the oil as you have to monitor progress via a small window in the crankcase.
The fill up is done in stages; you run the bike after the initial fill then let the oil settle. This is to allow for oil in the cooler and a little in the filter.
Of course I overfilled the sodding thing! No problem just take the oil plug out and drain off a cup full of Castrol finest; replace the plug.
Run up the engine and the level falls correctly.
Time for a test ride; first ride of any bike this year. Just a short 5 mile spin around the lanes.
This also allowed me to properly check the ABS delete I did for the first time; all good and I'm happy with the results.
