First pic is advanced as it is Before Top Dead Centre as the crank is moving anti-clockwise.Which of these two is the full advance that I align the dot with on the boyer cam assembly?
View attachment 354740View attachment 354741
That video where they point to the wrong timing mark is what got me confused to post the question yesterday and XS650.com to the rescue!I've done a few of these now. Without exception I have found that setting static timing as per the instructions gives very retarded timing. I now set it statically with the dot lined up and the timing plate as far anti clockwise as it goes. Then when it's adjusted properly with a timing light, the adjustment slot ends up pretty much in the middle of it's adjustment range.
I think BB do this purposely to avoid over advanced timing as a first off setting.
To add, there's a YouTube video that has been quoted to me several times by confused owners. And it's absolutely wrong. It's been up there over a decade and never corrected. The comments say it's wrong but not everyone reads the comments, it seems.
Reliable.10 mile test ride went good. Looked at plugs when it cooled down and looks good.
How has the reliability been on these things?
How much air do they need to get? Would mounting under the coil mount plate be ok or too much heat from engine when sitting idling?
Mine is same place and AFAIK cooling is not a problem. Reliability, I've had Boyer Bransden on a Commando, Z1B, 1970 Triumph 650, XS650 and 2002 Bullet 500 and have never had any problem with the ignition on any of those in many tens of thousands of miles. Set and forget.Reliable.
I believe the default position on a stock bike is with the box pushed up between the plates either side of the frame, into the void behind the steering tube. Mine is in there, I stuffed some pieces of foam in there to stop the box rattling around. It can't fall out because I mounted the ignition coil behind it.
If you all say I'll not have heat problems, that is likely where it will end up eventually.Good to hear the progress. I have to say, your choice and all that...... but I do prefer the box hidden away behind the steering stem tube.
Now I have foam pod air filters, I have considered moving the blue box to in front of the battery. But there seems to be tons of experience with the blue box tucked behind at the front of the bike. I'm probably going to leave it there.If you all say I'll not have heat problems, that is likely where it will end up eventually.
And the tech back-up is good. Used to be able to ring 'em and talk to a techie, these days got to use email but they still revert with an answer pretty quick.Raymond I agree entirely. I resent buying a product "designed for a XS 650" then having to make and modify parts so it fits.
Having said that I think it is a good bottom end of the market ignition , and the parts back up is good. So swings and roundabouts.
I agree. A rare case of a company that still answers emails within a few hours of a question being asked.And the tech back-up is good. Used to be able to ring 'em and talk to a techie, these days got to use email but they still revert with an answer pretty quick.
