Aluminum= air cooledIs aluminum heated than dipped in cold water, and copper heated and left to slowly cool, or is it the other way around?
Copper= cold water.
Aluminum isn't any harder to anneal, it's just different... 'cause it melts before glowing from the heat. Harder to tell when you reach the right temp.
Here's a "back yard" method...
Run a candle under the washer to deposit some soot on it. Now use your propane torch to burn the soot off. Soon as the soot's gone, it's hot enough to anneal itself. Unlike copper (and like steel) you let it air cool without quenching.
I've had to work a piece of aluminum where it took multiple annealing steps.. I'd say it can be annealed indefinitely.
There was one banjo that I couldn’t stop a leak and the solution was using a sealing washer. Ran that for well over 2 seasons without any sign of a leak. On that said connection, I tried copper, aluminum, both thick and thin as well as annealed copper. Must be an irregularity in the sealing surface a couldn’t see and the rubber must have compensated for that. I now have in hand, sealing washers from 3 different sources. They sure aren’t created equal and I’m suspecting the Chinese ones supplied with the banjos won’t be as good. One thing to note is they are also of different diameters.I like the copper seals better than aluminum. I think they seal better with less torque. However I installed a new rear and front caliper on a KZ im working on and they came with dowdy washers ( steel with rubber middle ) like the one with the bolt Bosco posted and I thought I would try them and they seem to work just fine but will keep my eye on them.
The basic design seems to be good. I wad reading up on oring materials and learned the best rubber for DOT3 or DOT4 brake fluid seems to be EPDM or SBR. These washers (Dowty), from Asian sources, will have rubber of unknown type. I’m expecting they would use the cheapest available, but at the same time hope they’d supply the correct material for the application (wishful thinking). In all the spots I’ve used them, they have been leak free so far. I suppose once sandwiched between metal and captured by the steel washer, even if the rubber wasn’t the ideal type, it may retain the fluid?They are popular on Brit bikes to make up for CENSORED tolerances.
Bought a bunch while messing with Norton petcocks/ fuel systems. They seem to do the job there.
Yes, there doesn’t seem to be a standard length. As mentioned in my earlier post, I was having concerns with the bolts being too short. My recenct Chinesium purchase has addressed this, but as per your post, there’s one hole in the splitter manifold that’s a bit shallower than others. If I put the wrong combo of bolt, fitting, washers, the bolt will bottom out.One thing @GLJ ran into was banjo bolts that were just a bit too long, the threads bottomed before the washer was tight enough to seal.
It's a common gotcha when sourcing replacement bits n bobs that parts designed to one standard are slightly different that those used by a different country's standard. SAE JIS have some conflicts like that. Add in chinese wil-fit manufacturing "standards" and we're off to the races.
Don't get me started on pipe thread "standards".![]()
It was round two of “science night” this evening. I tested both new and annealed copper crush washers once again for their bendability, this time measuring the force required with my fingerometer. The difference is quite noticeable. I also noted on my new batch of Chinese crush washers, they aren’t completely flat. They have a bit of an “edge” on the ID and OD, no doubt from the stamping process.@bazz I did a little experiment this evening. I tried bending a virgin copper washer and another new one that I annealed. What a difference between the two! The annealed one was very easy to bend. This might answer why I have such poor luck with sealing hydraulic fittings. I was always thinking a new washer should seal well out of the box. On the matter of annealing, I find that after the washer is heated up, it’s left with a black surface coating that doesn’t look smooth to the naked eye. I tried a grey 3M scuffing pad but the coatings a bugger to remove. Am I doing something wrong?
The Russell fittings I use sometimes come with a set of crush washers. They supply aluminum washers, not copper. Does aluminum seal better? I’m guessing they’re one time use?
I've pretty much always re-used the original copper washers and never had any leak issues. I very rarely replace them, just clean them up, sand them a little to remove any obvious imperfections and "grooves" on the sealing surfaces, then anneal them. I'm pretty sure I just use the little wire wheels in a Dremel to remove that black coating from the annealing process, it works well.
No, I don't think aluminum seals as well as copper, and yes, they're a one time use usually. I remember when BMW switched to the aluminum washers on their R bikes. Of course I tried them, but they didn't work as well as the original copper crush washers, so I've continued to use those. Now, this is on the drain and fill plugs for the motor, tranny, drive shaft, and rear end. Yes, there's lots of them, lol, about 8 I think. And for stubborn leakers, I'd switch to a red Bakelite washer, and that usually did the trick. But I don't think those would work on a brake line., annealed copper ones are your best bet.
Hmmmm, after reading Jim's post, I never knew aluminum could be annealed. Maybe I'll have to try that.
Interesting - noted. ThxThe other thing to add is when you anneal your new or used copper washers
Do it just before you plan to use them
Not days or weeks before hand
I don't know for sure if this makes a difference but some say it does
And it can't hurt
