tmkenney
Hey all, I've been building a 79 xs chopper for the last few months, and finally took it for a ride around the block tonight. I noticed that under acceleration more than about 5% throttle, it will sputter and slightly backfire. Not one big bang, just aggressive sputtering, makes me think its too lean. The bike will idle great and free rev while in neutral no problem. No hangups or lag. I will also say that putting the choke on will cause the bike to die within a few seconds once it's running. In trying to avoid pulling the carb bowls off 100 times again, what do you guys think? Currently has 27.5 pilots, and 142 mains. Screws are turned out 2 turns. I had 138 mains in, and after increasing to 142 I noticed no real difference, so I'm thinking its too lean on the pilot jets. Exhaust is straight pipes, and the intake is velocity stacks with mesh screens over them. I also made sure that the advance unit was free and not sticky, I removed and lubricated the assembly, as well as cleaned off the points.
