bankerbiker
Yeah, that is what I am afraid of. I still have an oil leak somewhere on that left side, but it appears I will be looking for a new rotor.Sounds like your rotor is bad. Age killed it no oil.
It is a 1983 XS650 Heritage Special, Canadian model (not sure how different it might be from the US version - maybe not at all). As far as I know, it has the factory TCI (is there a way to confirm that?).@bankerbiker , I moved the conversation over here from the oil seal thread. Works better here.
I rewind rotors. What year bike and does it have the factory TCI (ignition system)?
https://www.xs650.com/threads/rewound-alternator-rotor.54276/
I'm actually right on the border with the US. My Step-mom was Canadian born but a US citizen and lived in Michigan. I still have a step-sister and "cousins" in Michigan so yes, that is a definite alternative. I ordered scooter parts from Scooterworks in Chicago and would pick them up at an address in Michigan and bring them back across to Canada (all declared at the border of course!). I could do that again although my trips to the US have been curtailed for the last couple of years.I've prolly sent upwards of 50 rotors to Canada.... or should I say to an American address on the border. Got an American friend just south of the border?
We loosely refer to it here as the Canadian mafia....![]()
Only two issues to look for:My bike is the '83 Heritage Special. What issues do you see about working on the rotor? Would it help if I sent you any pictures, and specially of what?
Thanks. I am waiting for the puller to arrive (a couple of days away). I will check for the part # tomorrow, but I suspect this is the original part installed by Yamaha. I will be back to you when I can.Only two issues to look for:
Make sure to use a puller designed for it. A 2,3 or 4 jaw puller stands a good chance of bending it. All the (4 or 5) cores I've rejected was because the wrong puller bent the hell out of 'em.
Make sure there's a part # molded into the edge of the ring plate. If there's no part #, it's a Chinese forgery.
I am in Rochester, NY and if that is close enough for you to get to, Jim can ship it to me and you can pick it up. Just a thought.ve prolly sent upwards of 50 rotors to Canada.... or should I say to an American address on the border. Got an American friend just south of the border?
Thanks Bob. However Rochester is too far away, and it would be easier for me to use Michigan since I am right next door.I am in Rochester, NY and if that is close enough for you to get to, Jim can ship it to me and you can pick it up. Just a thought.
Wow, amazing news. it is said timing is everything. I hope to better check out and confirm that the rotor needs replacing by Friday once I get the puller. I'll keep you informed.You're in luck, I just got a TCI rotor core back in the mail today. I'll get started rewinding it. If it turns out you don't need it, no worries, someone else will grab it.
Just checked the rotor. Same number as the picture you show here - 3G1-10. I guess that means its an original.Only two issues to look for:
Another thought, How about checking the rotor on your other bike and see if the readings are the same?Just my 2 cents here, but if you are ordering a new clutch pushrod seal, order two. It is not uncommon to damage the first one on installation. Also, since you have two XS's now, it doesn't hurt to have a spare on hand. Cheap insurance if something goes wrong on the install so you don't have to wait another week for a new one.
Great advice willis, thanks. Unfortunately, the stuff is arriving today so too late to order two. I will be extra careful with all of the seals.Just my 2 cents here, but if you are ordering a new clutch pushrod seal, order two. It is not uncommon to damage the first one on installation. Also, since you have two XS's now, it doesn't hurt to have a spare on hand. Cheap insurance if something goes wrong on the install so you don't have to wait another week for a new one.
More sound advice. Thanks. I should have done that when I had the cover off for painting. This bike has started easily every time (the previous owner had been riding it annually so it had not been sitting like the '83) and my trickle charger takes no time to get it to full charge again and indicates a good battery. However, testing the stator could tell me if I am getting wonky readings from the multimeter.Another thought, How about checking the rotor on your other bike and see if the readings are the same?
