Cable building, throttle/clutch/brake/choke
festerandolini
Victoria, Australia
I am currently learning how to make a new throttle cable for my stock XS250, as i need it running and on the road so i can perform more dark sciences of speed and mechanicry. The new bars i have fitted onto the clamps needed a couple of inches of extra length for all of the cables (except electrical...?) and i have been busy.
The XS250 survived ownership and neglect at the hands of an unknown Victorian, who was the victim of a heinous crime 🫆, the worst known to motorcycle owners, THEFT. The 1978 XS250 was recovered at some point in the 20 teens and spent a very long time in the police 🚓 impound yard after being recovered, from a drug bust.
To steal the bike, or at least move it, i suppose from one place to the next, the lock barrel had been drilled out, and the same fate awaited the fuel cap. Once the blinkers had been removed, it was used for whatever nefarious purpose until it remained stowed in the shed of whatever drug operation forgotten and ignored until the raid. One of the cops who was present at the raid, purchased the bike once it went to auction and then it was ignored for another 7 or 8 years. He sold it on to the guy i purchased it and a rolling chassis of another xS250 (minus motor, tank and seat) for a fair price. I paid not much more for a basket case XS650 18 months later, and have no idea 💡 what i am doing.
Anyway, the bars. I foolishly chose 10" apes, cos- I'm a blonk, perhaps. Now i regret my choice because i have failed to make a cable.
I have tried using a couple of different methods of cable casting moulds. One was a bolt 🔩 with a slot and hole drilled through. Another was a block of wood 🪵 and some holes drilled on it, and the last method, using flat bar 6mm by 32mm and making a take down mould. I had tried using baker's fluid for etching the stainless steel cable prior to soft soldering the cast end on, and it failed. I had attempted to cast the lug on the end about 20 times now, and have wasted so much solder and lead, it's a good joke 🤣
I have kept researching techniques, and was pondering 🤔 the possibility of life not being all that important, when i stumbled upon yet another technique i had not tried. So at some point 👉 in this future, i will try bossweld ca 801, to etch, after using acetone to clean 🫧 🪥 any oil from the 2mm cable, and making sure to keep the wire from getting too hot.
It took many searches and re-wording of search terms to find that i needed a very strong acid flux, and that oily residue must be cleaned BEFORE etching.
Oh yeah nice 👍 i will suss it out ...
I did try messing with cables again and i managed to set 📐 1/2 a cable. I managed to make one end of a cable that passed the "pull" test. Using acetone to wash the cable, this gets the oil off, but you probably dont need it. Just soak the cable end in the 801 strong acid flux and then dry it off, heat it a little with a big solder iron. Maul the end a tiny bit, clean it again heat it and tin the end.
Once the clean, mauled end is tinned, put it in the mould or die and cast by dropping in molten lead and a teensy tiny bit of 60/40 resin core (less than a gram per 1/2 ounce).
Allow to cool 😎 🆒
Tap out of die/mould with a drift on the anvil, and test in vice. That's what worked today! Now for the other ends...
For soldering the cable ends I highly recommend getting one of these solder baths if you don't already have one. Available dirt cheap from Ali Express.
Post in thread 'Ninja EX500 carbs on an XS650?' https://www.xs650.com/threads/ninja-ex500-carbs-on-an-xs650.13070/post-872691
Right, i know what these are, i really want one for casting lead sinkers, and other soft metal castings. There is something else i use a lot of lead for... Probably slingshot and sling pellets. Love lobbing the lead eggs out of the Baeleric style sling. Pretty keen on getting an ultrasonic cleaner from ChinaBay. Maybe even 2? Use the large one for washing parts, having a small diaphragm pump to pull fluid from the large unit and filter into the small unit and then back to the large unit. Maybe just with a gravity return? I don't know... I just know we need to wash parts all the time, and having the ultrasonic cleaner makes light work of heavy scrubbing.
But the solder bath, probably isn't the tool i need for casting cable ends, yet.
