I have a lot of motorcycles, more than I probably should. I have accumulated them over the years, half are projects as in "non running" and the other half need maintenance so they don't end up on the project list. I have way too many to afford the upkeep on but I still want more. About a month ago I picked up another xs650 (my third) off marketplace. My other two are a Cafe/Tracker and a Chopper and are becoming perpetual projects due to running into problems and losing "creative vision". This one,however, was completely stock and original, all the pieces were there, just needed a battery and clean gas should be no problem, or so I thought. I found metal shavings and black plastic bits while changing the oil, tell tale signs of a chewed up cam chain guide. Having had never dug into a motor that deep before I decided I would try it on a spare motor that I had already on a stand instead of pulling the existing one out of the bike. and who knows maybe it would be in better shape and I could just swap it in place and do a proper rebuild on the original. It was not. it was way worse.unfortunately. I named it Mallory. I name all my vehicles it's easier for me than saying "the chopper" or other Xs650 that has the tail hoop cut off or the one that's all original.. Instead I say "Yoshimi". "Persephone" or "Ruby" ( a 1981 special 2 in new ruby red) I even bought it on a Tuesday if you believe it. So this is the story of Mallory and the state she is in
So I read threads and watched videos and learned that I needed to take the head off to get to the guide. I started the process in my carport as the weather had been, it was already there and heavy AF to move. Then it started raining and I knew it would probably develop rust if I pulled the head out there and left it for any amount of time so I packed it t the back door of the garage and got it up onto a harbor freight welding table without any damage save for a few disks in my lower back. Then the fun began. If you have watched Night flyers video on removing the head He suggests not trying to keep the chain in tact as he did in the video and I concur. That was a PITA to get out and I was afraid that I had scratched the cam lobes but didn't. I got the head off and the front chain guide out and it definitely needs replaced. Well as far as my novice eye can tell. I'm sure that there are alot of other issues and tell tale signs that the Gurus can see and shed light on. here's a few pictures, she's a dirty girl but I'm hoping to I can clean her up make her presentable
Also, I found this. I'm a little worried she might have a crack problem
should I be concerned?
Any info, advice, suggestions would be greatly appreciated as these are uncharted waters for me.
should I be concerned?Any info, advice, suggestions would be greatly appreciated as these are uncharted waters for me.
![IMG_3690[1].JPG IMG_3690[1].JPG](https://www.xs650.com/data/attachments/362/362826-a6593633a799819efadc4c2987f8a07a.jpg)
![IMG_3691[1].JPG IMG_3691[1].JPG](https://www.xs650.com/data/attachments/362/362827-b823d67ef14f6102f49543a77f24d605.jpg)
![IMG_3687[1].JPG IMG_3687[1].JPG](https://www.xs650.com/data/attachments/362/362829-f3af7abcd8f97311e5f3546b2cfba59b.jpg)
![IMG_3688[1].JPG IMG_3688[1].JPG](https://www.xs650.com/data/attachments/362/362830-f05f3289d5372d7200e2587fab87f718.jpg)
![IMG_3689[1].JPG IMG_3689[1].JPG](https://www.xs650.com/data/attachments/362/362831-d9aed0722ff239ef48384a57be13c74e.jpg)
![IMG_3686[1].JPG IMG_3686[1].JPG](https://www.xs650.com/data/attachments/362/362828-1dc0d3c1d7b007c3ff3820c3abc4af2f.jpg)
![IMG_3695[1].JPG IMG_3695[1].JPG](https://www.xs650.com/data/attachments/362/362846-9471925f9042f958918dcf0536671ff6.jpg)
![IMG_3708[1].JPG IMG_3708[1].JPG](https://www.xs650.com/data/attachments/362/362847-2a1b380a49cf71779f95e462263e6662.jpg)
![IMG_3705[1].JPG IMG_3705[1].JPG](https://www.xs650.com/data/attachments/362/362848-6299715889458f9fbbd4b357fe9c4d43.jpg)
![IMG_3706[1].JPG IMG_3706[1].JPG](https://www.xs650.com/data/attachments/362/362849-797d375aedd6ab685749efabcc9bd579.jpg)
![IMG_3704[1].JPG IMG_3704[1].JPG](https://www.xs650.com/data/attachments/362/362850-f297e54de3b8445818c5d0059240113f.jpg)
