Pulled my drain plug and oil strainer cover today to find the dreaded cam chain guide bits. When replacing the guide, does it also make sense to replace the chain as well since I'm already in there?
Jim, can you elaborate on exactly what you are suggesting in terms of a "full top end refresh"?Yes... absolutely. Might as well do a full top end refresh while it's apart.
but it's always a bit daunting the first time around on a different type of engine until you learn all the tricks/pitfalls.
I have four thousand miles on the Hoos guide. Happy happy.Gary hoos hoos racing, many satisfied users here.
http://www.hoosracing.com/650productpictures.html
down a bit on the left.
I'd run the existing stock tensioner - pic shows slight wear and I'd be suspicious of Mike's/Yambits/ Heiden tensioner quality too (got a couple rebuilt 20k engines with originals in them)There is some wear on the tensioner (picture). I would just replace it, but OEM is no longer available and I wonder about the quality of the aftermarket ones. Any suggestions; just leave it or replace with aftermarket?
I already bought the cam chain guide from Gary, but was asking about also replacing the tensioner.
Sometimes you never know what you're going to find. While pulling the head, I noticed that two of the valves, one exhaust and one intake, each had a little buggered area on the side. I also saw that someone had installed thread inserts in the plug holes. Today while dropping off parts at the machine shop they informed me that two of my valves, the buggered ones, were also slightly bent. Looking at things we surmised that whoever installed the thread inserts had run the tap in so far that it hit the valves that were open at the time! Dang, I wonder how much force they had to use to keep cranking on that tap enough to bend valves? Looks like I'm in for a fresh set of valves.
