Shoulda added.... Jeff, you were right. Apologies for ever doubting you.
Because 11.5 volts at the starter relay doesn't get it to close and spin the starter.Which reminds me, why are we chasing power? I forgot what the original problem is.... sorry.![]()
Just a thing I ran across on my SG (tracker) when it did blow a main fuse - the rotor had dropped to ~2 Ohms. I then rewired the bike and had you rewind that rotor. IDK if the Type B regs are ahead of the fuse box, but I suspect they may beShoulda added.... Jeff, you were right. Apologies for ever doubting you.
Well, as I said, checking current draw might be more useful in finding out where the power being lost at. Seeing a voltage drop (like you're doing) could be either higher than normal resistance to a component, or that component drawing more current than it's supposed to.... checking to see how much current is being drawn will tell us which it is.Because 11.5 volts at the starter relay doesn't get it to close and spin the starter.
I should have explained a little better....Well, as I said, checking current draw might be more useful in finding out where the power being lost at. Seeing a voltage drop (like you're doing) could be either higher than normal resistance to a component, or that component drawing more current than it's supposed to.... checking to see how much current is being drawn will tell us which it is.
Those all look normal..... correct except for the 1A with *all else.* It might be normal or it might be something pulling power that shouldn't be. Off the top of my head I can't think what. Try disconnecting different stuff and see if it goes away. Just thought, were the taillight or indicator light on? That might explain it.In amps this time:
Ignition circuit draws +2.4 amps
Regulator draws +2.4 amps
All else draws +1 amp
Sure they were. My 72 only has 1 20amp fuse for the whole bike.A shorted regulator would blow the 20A main and kill the whole bike. Surely Yamaha wasn't that dumb?![]()
I think you need to investigate this further. In my experience 11.5 volts is more than enough to pull in a 12 volt solenoid.Because 11.5 volts at the starter relay doesn't get it to close and spin the starter.
Agree. That's why I asked if the battery has been load tested.I think you need to investigate this further. In my experience 11.5 volts is more than enough to pull in a 12 volt solenoid.
Yep, all the way up to '77 I believe.Sure they were. My 72 only has 1 20amp fuse for the whole bike.
Ok, given that peculiarity and the fact you're losing power to the solenoid before Y is energized; points to a problem with the Safety Relay and its switching of the R/W (that emanates from R/Y circuit)Odd, since I can turn my headlight on or off with the engine running. I can't quite tell where the unplugged wire is coming from. Is the headlight safety relay the same as the safety relay? I thought the safety relay disengaged the starter when the engine started, or does it do both?
Be easy enough to make a jumper and go around the safety relay. It's the R/W that feeds the solenoid though. Disregard the red jumper drawn in, it's for something else.Ok, given that peculiarity and the fact you're losing power to the solenoid before Y is energized; points to a problem with the Safety Relay and its switching of the R/Y circuit
I have about 11.5 volts at the starter relay. However, when testing this I noticed that the voltage was intermittent. I traced it back to the safety relay, which had constant power going in, but intermittent power going out (and to the starter relay). I popped the casing off the safety relay and checked to see if the relay was activating and cutting the power; it wasn't. So I gave the relay contacts a good cleaning, and for now things seem to be working. Because this was an intermittent issue, only time will tell.I think he needs to connect his voltmeter to the coil posts of the solenoid and see what he has when pressing the starter button.
That education is worth it's weight in gold.in doing all this work I learned a lot about how these bikes are wired, etc., so not a total waste of time.
