cam chain guide
slapshot
Huron sd
In the small oil filter in side of the clutch cover on the xs650 it showed small pieces of plastic the size of a pin head and small flakes of aluminum when was changing it. A piece plastic as long as a tooth pick came out the motor sounds as it should when running should the cam guides be replaced. Thanks jim
You can "drag and drop" into the comment box, you can "copy and paste" into the comment box... and just below the comment box on the left is a button that says "attach files." click on that and follow the prompts. I'm sure there's other ways too, but those are the most common ways.
The tooth pick size chunk of plastic came out of the sump drain hole I did take the filter plate off and the look good no chunks on it
