Cam Seal Leaking... still
I reckon that this has to be wishful thinking.
2026 xs650. View attachment 356950
I think it safe to say that it's not happening. I expect it's highly unlikely that I would buy it anyway. The old ones work fine. It's the same as my 1957 Kirby vacuum. It still works fine. Why replace it? I guess I'm making a case for planned obsolescence. But then I'd think it junk, and I still wouldn't buy it.
Seal, gasket, and o-ring. I like the original red o-rings (I think they're silicone) and re-use them usually. I tried the black ones that came in the Athena gasket kit but they deformed (turned "square") after a few years. I couldn't re-use them when I removed the housings. Luckily, I saved the original red ones, lol. They were still "round" so back on they went.
Indeed, the camshaft sealing is one area where I wouldn't use aftermarket hardware. The Athena O rings are almost certain to be nitrile material and not up to the job.
And also make sure you push the seal in as deep as it will go, so it's even with the back of the housing. The cam end doesn't stick out much so the seal needs to be pressed in deep like this for it's seal lip to get on the end of the cam.
In fact, you may want to press it in even deeper, so it hangs out the back of the housing about a MM or so.
Did this hold up with no leaks?
Has anyone tried reversing the seal so the lip sits on a different part of the cam ?
Yes I know it sounds wrong but a mate of mine noticed a difference in a Ducati workshop manual where it showed the crankshaft feed oil seal which is under considerable pressure fitted either way
My mate got onto Ducati and they said don't worry about it and it'd work either way!
As he has an inquisitive mind he tried the seal either way with an oil pressure gauge fitted
And sure enough the pressure was exactly the same
I think he said it was around 80psi
I can only assume the pressure isn't high enough to lift the skirt of the seal?
Are you using Yamaha camshaft seals and carrier O rings? Some of the aftermarket seals and O rings are nitrile material and not up to the job. It's a very difficult environment up there on the cylinder head. I would advocate only using Yamaha parts for that job.
Also this -
Post in thread 'Tips and tricks' https://www.xs650.com/threads/tips-and-tricks.69012/post-896454
