Can a head gasket leak into the crankcase?
So here it is! After about 120ish miles. For comparison the photo with an oil puddle on the carby was about 20 miles!
I think I can live with this, so I reckon I'll call it good. Thanks again Jim, and thanks everyone for chipping in. Chirping seems to stop under load and come back at idle or very light loads. Can disappear when fully hot then randomly start again. Something probably not right there, but maybe good enough. I'll either tee it back into the airboxes or maybe a cheap catch can off ebay.
I do have this going on:
But I'm hoping that's from the pot I had catching the oil. It's open topped and I didn't remove it yet because you have to take the airboxes off and i was being lazy.
My 1968 Ford Fairmont had a road draft tube, never breathed heavy though so I never saw anything come out it.
I get a weird chirping noise which I thought was the check valve, but it's definitely not. I have no idea what's going on with that, it sounds like a baby bird, or far off car alarm.
That chirping is almost always a choke housing that's loose.
Thanks gggGarry, buy it's definitely coming out the breather. Gets louder if I move my right leg out from the tank so it's not blocking the sound. I'll check the choke screws anyway, since I did replace the plungers.
I also have a very mild chirp at idle from the left hand exhaust. I couldn't reach the choke screws on that side though, obviously.
Ah! I think my exhaust one is something to do with the butterfly shaft seals. I recall I made a mistake when buying them and ended up with 3 instead of 4.
The other chirp is 100% coming from the breather. With it sitting on top of the carb, it's very easy to pinpoint. It was there Monday morning but after I changed the oil Monday night it stopped. Coincidence I'm sure, will see tomorrow.
Well it's been a minute, got busy etc. I gotta say, thanks and sorry gggGarry! The chirp that I said was "definitely" coming from the breather, definitely isn't! I happened to be crouching down beside the bike while it was warming up yesterday (haven't ridden for a few weeks) and I plugged the breather pipe with my thumb and it was abundantly clear the chirping is coming from the carb (or at least definitely not the breather). Will pull the carbs and go straight to that left hand choke.
