Hello,
I have a stock 1975 XS650B. The points are finally getting to me. I'm thinking about getting a Pamco electronic ignition.
According to the Pamco website, it says the ignition requires a special dual-output ignition coil. Here's a link to it.
So here's the issue. The BS38 carbs on the '75 DO NOT have vacuum barbs for syncing -- so I have to use the dead cylinder method. Also it has separate throttles (and thus, separate idles, I'll get to that in a minute).
I sync the carbs by yanking the right spark plug cable, sticking a very thin metal object (ie: a washer) between the idle adjuster screw and the throttle tab on the left side, the slight thickness of the washer gives about a 1K RPM boost. So I turn the left idle screw to make the idle to, say, 2.2K RPM. Then I'll switch off the engine, replace the right spark plug cable, yank the left cable, swap the washer to under the right-side idle adjuster screw, fire it up and match the right idle to 2.2K RPM. When I pull out the washer and replace the spark plug cable, the carbs are synced.
But I can't do this method because according to Mike's XS, the dual-output coil has a warning that says: "Caution! Do not operate or apply power to the ignition system with one or both spark plugs disconnected." Apparently, it fries the coil.
So if I get a Pamco (or Boyer), how do I sync my barb-less carbs if pulling a spark plug cable fries the dual-output coil? I've thought about swapping the '75 carbs with a '76 set (that has vacuum barbs), but the '76 DOES NOT have separate throttles/idles, which means it would require a whole entire process to convert my dual throttle to a single throttle, all of which seems like a big costly mess just to be able to use a Pamco. Does this mean if I use a Pamco, I have to "guess" my sync by ear? It seems ironic to get an electronic ignition to get precise timing, at a cost of precise carb sync. Could I use the stock coils that aren't so fragile?
Any advice appreciated, thanks!
