Can someone explain this cam
jay760
XS650 Guru
Somerset
Can someone explain how the cam on the right works, ive seen a couple on Facebook the last couple of days and just cannot work it out, the lobes seem to be 180, degrees apart with the cam moving at half the rate of the crank this would meen the piston would be travelling in the direction as either valve opens, i just cant see how it is possible to work
Makes perfect sense to me.
I've seen very little about what actually went into the OW/OU 72, compared to the standard XS engine.
If they had to alter the rocker geometry for the narrow valve angle, the rocker pads might have been riding on opposite sides of the cam, rather than both at the top, if that makes any sense.
Regardless the valve angles and rocker ratio that is an EXTREMELY wide LSA!
Often in performance applications that angle is closed up compared to road going cam timing.
Interesting to say the least.
Wouldn't the LSA be referred to crankshaft degrees? Theoretically, the rockers could be L-shaped or whatever, like for example a Ducati closing rocker arm. Most of us are used to see camshafts where lifters or rockers all are "inline", and camshaft lobes placed accordingly.
