can you do a re-bore with a file?
jaybar6
Manchester, uk
I don't have a lathe or a milling machine, so i thought I would buy some oversize pistons and file the cylinder out until the piston slides in smoothly. Maybe a grinding head would be quicker with a drill. any thoughts?
I don't think that could be done in a million years but I met a man many years ago, worked in India repairing army lorries at the end of WW2 told me how they did a rebore without the proper equipment.
They cut the old piston down the middle, put the block on the ground, replaced the piston into the bore with a wooden wedge to force it against the sides and a long piece of wood as a handle, utilised river mud as grinding paste and punkah-wallahed the piston up and down the bore, patiently rotating and measuring until they had removed enough metal for the new oversize piston to fit.
Equipment and parts were expensive, labour was cheap.
What could possibly go wrong with that plan?
Get it done by an expert - Rebores in the UK are not very expensive. Then you will need to check the ring gaps, this can be done with a feeler gauge and a "File". The direction of filing is important so you do not chip off the chrome coating the rings might have.
I used Cardiff Pistons for my rebore about 7 Years ago and it cost £150 for both cylinders. I would guess the price now would be about £300. Shop around and look for engine machine shops that specialize in reboring. Bike shops will do it but generally via a 3rd Party so you will pay a commission.
I'm assuming you are jesting
But if not
No you can't
Perhaps the Mancunian dampness has affected his thinking?
But to answer th question, yes, of course you can but you will need to acquire a special sort of file to do the job.
It looks like this....
Yes Raymond, that is the answer! I can use the old piston to do the same job. Brilliant!
That is £300 including the pistons?
As Skull has mentioned above, many of us have used the pistons from "cruzinimage" and the pricing is very good. When I ordered mine they arrived from Japan within 1 week. Cardiff Pistons measured the pistons and found them to be identical - that's modern machining for ya.
