CaptCardboard
You mean "anti-massage action" Imma bolt those things down!Vibration dampening to the feet.
If it makes you feel any better, looks like the stud was previously cranked on and cracked... judging by the rust stains. Weakened to the point of failure before you.This, I feel, is a perfect hamhanded example on why the delicate work of disassembling and replacing my shaft seals may not be the job for me.
Well today was fun! I took my carbs apart again to see if I can't smooth thing
s out a bit.
I found I didn't secure my s
lide to the diaphragms quite right and the right side (the bitchy side) slide had rotated nearly 180 degrees backwards. I reglued my slides and diaphragms, hopefully better than last.
I also took gggGary's advice and drizzled some wintergreen oil on my shaft seals before slathering em with silicone grease.
Put it all back together with new plugs and synced the carbs again. The damned thing hasn't run better in my care!
Fired up on the second kick. No more hesitation on the throttle! I'm still getting a couple little baby backfires once in a while as I decelerate in gear, but not loud pops every single time I slow down to a light. I suppose it could be that my absolutely cheapest possible vacuum gauges aren't reading quite right, but it's a quad set and I swapped the leads around between all four gauges to make sure they were balanced right. I'm thinking some tinkering with the mix screw might be in order at this point.
Either way it's not perfect, but at this point it's perfectly acceptable.
I also finally bought a 36mm socket to properly tighten my sprocket nut. Everything there went fine until I was finishing up and putting my foot pegs back on. Snapped one of the studs off.. dammit!
This, I feel, is a perfect hamhanded example on why the delicate work of disassembling and replacing my shaft seals may not be the.
Are you sure it's not coming from the drilled, double wall, vent hole hiding under the finned clamp?I just noticed a little puff of smoke coming out of the right side where the exhaust pipe mounts to the engine when starting my bike the other day.
Any recs for decent exhaust gaskets? I see two different types on MikesXS that say they fit my bike, but I'm not sure which to grab.
I figure I'll replace gaskets on both sides while I'm at it.
Yep. It's not uncommon for a leak at the header causing a little popping on decel.Side question, would an exhaust leak on the right side contribute to backfiring on the same side when decelerating?
Those sound like good numbers.
Not familiar with lithium iron batterys, 13.4 sounds low to me. 14.4 to me would be better.Revving to +/- 4k: 13.4V
It's stock.PMA or stock alternator?
I had to double check, cuz I hear lithium ION all the time, but not iron. Nevertheless, there she is.Not familiar with lithium iron batterys, 13.4 sounds low to me. 14.4 to me would be better.
