Randy N
I am having some issues with the left carb on my XS2. it’s been a lot of years since I’ve been into one and wanted to ask a couple questions and pose the problem before I get into it.
The left cylinder is not firing at idle, and if I play with the throttle and gently bring it up off idle, it will fire and then run fine. If I crack it open from idle, the bike will die. The right cylinder is firing fine. I am certainly getting a lot of black smoke so it seems to be running rich. I checked the timing and the points and recapped them as the left side was not gapped properly.
I did ask the previous owner where he had the needle clip set and he does not recall. I’m thinking I should pull the left carb off and go through it.
Any thoughts or advice from the group here?
Thanks
Thanks
