bonesaw
Huney__Bear
Problem: right carb sneezes and stumbles the bike to a stall. Idle is low because of the cam and if I set my idle any higher I get a hanging idle on deceleration.
Why would one sneeze? Improper adujstment of the mixture screw?
Tried dead cylinder method, the right carbs mixture screw is facing the backbone of the front frame loop and I cannot access the screw while the carb is on and running...
Air leak tested with wd40
Plugs look rich on the threads but a little white on the top of the insulator. The rest of the insulator looks tan/darker.
Specs:
1980 xs650
750 bigbore
Performance cam
Pamco
HHB PMA
PWK Flatslide carbs with pancake pod filters
Pandemonium ya mama open exhaust.
Billet intake mounts
Any insight helps.
Specs:
1980 xs650
750 bigbore
Performance cam
Pamco
HHB PMA
Any insight helps.
