FWIW I think you have done an admirable job tracking down and correcting potential issues. Makes me think perhaps I should check that junk body for a similar issue.
Thanks.FWIW I think you have done an admirable job tracking down and correcting potential issues. Makes me think perhaps I should check that junk body for a similar issue.
This maybe an aside, but still relevant. I have been told, by a luminary in the XS650 field, that the VM carburetors are really a design for 2-strokes. The aerated design of the BS carburetor emulsion tube is much better for 4-strokes and makes these BS carbs better suited overall for the XS. I am not an expert on VM carburetors and would be curious to hear opinions.Read the threads on this. Lots of people run VM34 Mikuni carburetors “Like a boss!” Those who struggle with the stock CVs also struggle with setting up VMs. FWIW, I recall @grizld1 recommended VM32.
CVs work great on the street once you get them right. Stay the course. Persevere.
thanks, jim. One thing for sure, the VM carbs don't have the slide lagMikuni carbs were originally a knockoff of Amal carbs. They weren't designed for either 2 or 4 strokes, they'll run equally well on both. It's all in the tuning. You can tune them for either engine equally well.
Good question. Yes, I could and I wouldn't have ordered the M3 x 8mm screws if I had known what I know now. The 8mm long ones that I bought sit deeper into the throttle shaft countersink and as a result are a bit too long. 6mm ones would have been better. 20:20 hindsight is a wonderful thing.If your going to loctite the screws, then why not just reuse the originals?
I would not try to dissuade anyone from doing so.I'd think they peened them over for a reason.
Is it worth sucking a screw into a cylinder?
That's one of those few things I wouldn't leave to chance.![]()
Worth a look.Ok, home for a minute so I dug that carb body out. The broken needle does not appear to be my issue so I’m going back to my junk body theory, lol.View attachment 333038
