DBLSHOT12
Hello everyone, I have a 1980 XS650 special that I could use some help with. I purchased the bike last year and found it was running very hot, so since it has K&N pod filters and 2 into 1 exhaust, I thought it might need re-jetting. I also checked to see if it had a dead cylinder by pulling the spark plug wire, I later found out doing so kills the coils. I always learn the hard way! I also found the wire connection from the regulator/rectifier was burned and melted. So, I replaced the coils and regulator/rectifier and repaired the wiring. Then I adjusted the cam chain and valves and re-jetted and rebuilt the carbs. I changed the main jet from 132.5 to 135and the piolet jet from 42.5 to 45, I set the floats at 27.3mm and set the air mixture at 1 3/4 turns. I have tried starting the bike and it will only run with the choke on, if I give it any gas it dies immediately. What am I doing wrong? Any help with this would be greatly appreciated.
