I used the entire contents that Caswell sent to me, therefore I have to assume my mix is perfect. As I recall the temperature that I was working in was neither hot nor cold and it took a good bit of time to set up. The tank is now stored in the house and had no fuel exposure.In my last job, R & D at a plastics compounder, we set or product in a xylene bath. Any polyethylene that had not crosslinked(cured) would dissove in the xylene and a very careful measurement (grams to 5 decimal places) would reveal the level of cure. If these epoxy liners have a hint of bad cure, a hint of the wrong mix ratio or some other system failure then it is only a matter of time. I know very little about these systems, about the epoxy used or about the chemical make up.
This thread concerns me because I took a very rusty tank to very clean metal. If Caswell needs rust to grip, they should insist it be so. I gave a tank to a friend of mine. There was a liner in it that subsequently failed. He mechanically removed the loose parts of the liner and the rust by shaking around loose hardware. He put Caswell over the old liner and the rust. I believe this was at least seven years ago and he still has the bike. He has no tank issue as of late. I would have believed my way to be far better, but now, I'm having doubts.
