I removed my rotor and cleaned the slip rings. Before i was barely getting a reading but now I'm getting a healthy reading of 5.3ohms ( manual states 5-7ohms as the correct range). When testing the ground for continuity ( neg probe on frame or nut and pos on slip rings) it shows no continuity ( as it should be via the manual).
Now here's the issue - when I install the brushes I'm getting continuity. When testing the brushes both show continuity.
What's the issue? Brushes are brand new from MikeXS - is the insulation block/holder the culprit?
