Charging System Component ID (83 Heritage Spec - STOCK)
maximusrising
XS650.com Supporter
Clinton, MA
Hello Community,
Could I get names of the parts in the pictures? It's not charging and it fails the slap test, (by the way so does my 2004 Honda Shadow - is that completely different?) so I need to start troubleshooting but I'm not sure what's what.
Also, regarding the awesome write up by Jim, "...all you need to do is locate the green wire at the regulator plug and make a jump from it to ground." Question - break the connection to ground or ADD a path to ground?
Thanks as always.
John 1983 XS650SK Stock
jetmechmarty
Project collector
XS650.com Supporter
Coldwater, Mississippi
Since you have accessed the alternator, you need to access the copper rings on the rotor. You'll need a multimeter. The resistance between the copper rings has to be about 5 ohms. I expect yours is less than 3. That is the most likely culprit and needs to be checked first. You can access the rings by removing the brushes. Check the brush length, killing two birds with one stone.
5twins
XS650 Guru
WNY
..... and the first two items in your pics don't relate to the charging system, only the third one does.
maximusrising
XS650.com Supporter
Clinton, MA
Thanks, always appreciate the help! Not knowing what they were is why I asked, it is clear now.
Electrical issues confound me, shouldn't, but do. Thanks again!!
maximusrising
XS650.com Supporter
Clinton, MA
Rotor ohms ... not good. End of search for charging issue? Anyone know which connector (if any) is voltage reg? That thing is IN there and I hate taking off the air boxes. Well I actually hate putting them back on but same difference. Never mind the Meter etc. picture Can't figure out how to delete it.
Happy long weekend!
