Chopper Axle Plates (Hardtail Axle Plates)
Price
$34.95
Ships Worldwide
Bobber33 shared some pictures in his latest build thread on a good method to attach the axle plates to the tubes. Draw a line down the center of the tube and cut a 3/8" slot on the inside of the center line.
After welding, the outside will look like this:
The inside will look like this:
There are many other methods to attach the plates, but this is the one I like best when using the stock XS650 wheel and stock axle plate spacing. This will help avoid chain clearance issues.
Travis do you have a site up yet?? I def need a set of these this week so I can mock up my tail, I have a '74 and the ends of the stock plates are open, thinkin this shouldnt make a difference tho
travis, are you still around?? I need the axle spacers for the plates.. thanks. also sent you an email..
COOL!!!
So does that mean your hard tail kits can come with 1" axle plates?????
:DI have a busa wheel that wants to go onto a Hard tail.....
Travis, website looks great. I'd be interested in buying mounting tab set "c" for shock mounts unless you suggest a better option. Also wondering if you might start selling frame slugs soon?
