Wanted - Clutch Actuator Housing
Rochester WA
Ah... the clutch actuator housing. I know I have a few, but right now I can't for the life of me remember where I put 'em. Hopefully someone else will have one readily at hand.
If this ad's still up when I run across 'em, I'll let you know. Don't wait on me though.
Yep that's the part! No worries! If you find one let me know please!
piece top left, complete assembly at mikes is $64 I have some housings.
hello GaRRRRy , i just happened to be clearing out all my extra parts, Ill send you a photo of one and see if you want it, it will be free, so don't try and low ball me I know what I have.
I admit to thinking about modding a short arm into a longer arm. The holy grail is one that reduces hand pressure at the end of the stroke so holding in the clutch is easier.... I've looked a few times at a three ball clutch ramp set up, as used on some older Hondas, thinking there are some real possibilities in designing a variable ramp clutch actuator.
More
I might have an extra one off my XS400 that I'm pretty sure is completely identical to the 650, that I noticed at least. I would have to do some digging.
I've also been wanting to try and retrofit an actuator from a different bike. The one off my '05 sportster looks pretty identical, and it annoys me how much smoother and easier the action is compared to my 650, i still love it though.
Also want to design a nice hidden hydraulic clutch slave like another member here started and almost finished but thats a whole 'nother story..
hey GAR-y is that part the one you need?
OOPS! i need to pay more attention, I thought Gary needed the part!
I now see the erorr of my ways.
Beck built fab, do you need the part?
i send it your way sir, it will arrive from apcustomfab & cycles, but you have to show us all what your using it for :umm:
Thanks man!! Any idea what year it is from? I'm going to be using it for a mock up piece for my modified worm gears. I found out the hard way that there are differences in worm gears from different years. Going to get as many as I can from different years and make sure the worm gear I buy for my customers matches the year and housing on their motor
did you get ur zip code wrong, had to resend it after googling your address , google says the zip code ends in a 9. not an 8 so its on its way to 98579 now
Similar threads
