I'm having an issue with my clutch grabbing when the engine gets warmed up. Shifts fine when riding. When I come to a stop after about 30-45 seconds the clutch starts grabbing and will eventually take off. (First time it done it it nearly pulled me into traffic)
It has a new clutch and new clutch cable. I've been all over the forums searching, I've made every adjustment that has been suggested. Could it be the oil? I just run 10w30... also I'm fairly certian I failed to soak my friction disks prior to install. (Hadn't messed with a wet clutch in a while)
Should I replace it again and properly soak the new plates? I'm about to do a full service on it. Oil , filters , tune up ect. What oil should I run?
Thanks for any info Y'all, it's much appreciated.
Lucky
Lucky
