I took apart the clutch today just to check things out for the upcoming season. Upon disassembly, I found there wasn’t a lock washer behind the nut that secures the clutch housing to its shaft. There’s supposed to be a Belleville washer there. I don’t have a dealer close by so I’m going to try to find one at an industrial supplier. Can someone supply me with dimensions - ID and OD? The shaft is 18mm so I believe the standard size Belleville washer will have a 19mm ID? I’d like to confirm that though.
I also noticed several of the cushion springs were not tight in the housing. 3 of them couldn’t be moved with my finger but the other 3 could be rotated in the recess and a couple had a minimal amount of end play. The looser springs are not broken. Is this cause for concern and spring replacement?
