DBLSHOT12
Hi everyone, I have a few questions about replacing the coil in my 1980 XS650. I purchased an aftermarket coil and would like to know which wire goes to the + side of the new coil, there is a red wire with a white stripe and an orange wire. My thought is the red & white wire should go to the positive side and the orange to the negative side. Looking at the wiring diagram, it shows the R/W wire coming from the on/off switch and the orange wire coming from the exciter, please let me know if I'm correct as I don't want to burn up the new coil. Also does it matter which spark plug wire goes to which plug or do they both fire at the same time? Any help with this is greatly appreciated as I found out the hard way not to disconnect the spark plug with the motor running! Story of my life - If there is a hard way to do something, I will find it!!!
