The stock copper banjo fitting gaskets are about 1.5 mm thick and the only ones I can find locally are 1.0 mm thick. Would they work O.K.?
My new Russell fittings came with aluminum washers and I bought a spare pack from them that were aluminum as well. I wondered if they sealed better or it was a cost saving measure? Aluminum work ok but are more difficult to anneal. @Jim explained the process in another thread. If I find it I’ll post it.I have been using aluminum washers
I only use the aluminum washers one time. Never tried to anneal an aluminum washer. My BMWs used aluminum washers for all the plugs on bike. Spiegler lines use aluminum washers.My new Russell fittings came with aluminum washers and I bought a spare pack from them that were aluminum as well. I wondered if they sealed better or it was a cost saving measure? Aluminum work ok but are more difficult to anneal. @Jim explained the process in another thread. If I find it I’ll post it.
I saw a short video on annealing aluminum that I think fit this purpose. The aluminum was marked with a Sharpie. It was then heated with a torch to the point that the ink disappeared. The demonstrator cooled it slowly, then demonstrated how soft it was.I only use the aluminum washers one time. Never tried to anneal an aluminum washer. My BMWs used aluminum washers for all the plugs on bike. Spiegler lines use aluminum washers.
A candle will do the same. Run it under the aluminum and let the soot coat it, then the torch to burn it off/anneal the part.I saw a short video on annealing aluminum that I think fit this purpose. The aluminum was marked with a Sharpie. It was then heated with a torch to the point that the ink disappeared. The demonstrator cooled it slowly, then demonstrated how soft it was.
Used that method when I worked at the Freightliner dealership in the late 70's in order to straighten/shrink floors that got wrinkled in jackknifes. But we used a rosebud torch. Works great.A candle will do the same. Run it under the aluminum and let the soot coat it, then the torch to burn it off/anneal the part.
Never thought of using a Sharpie. Pretty slick.
Yes, an oxy/acetylene torch set very rich will soot like crazy... perfect for this application. Used that quiet a bit myself.But we used a rosebud torch. Works great.
The nice thing about using the torch is it's quick and easy. Use the torch to "soot" the part, add a little oxygen to clean up the flame and then use it to heat the part. Quick and easy.Yes, an oxy/acetylene torch set very rich will soot like crazy... perfect for this application. Used that quiet a bit myself.
The trick is removing the heat before the panel/part becomes a silver blob on the floor.The nice thing about using the torch is it's quick and easy. Use the torch to "soot" the part, add a little oxygen to clean up the flame and then use it to heat the part. Quick and easy.
Nor should you.I have only used Honda brake line washers for almost 50 years and never had an issue, I buy them 50 at a time
From the dealer? That must be costly.I have only used Honda brake line washers for almost 50 years and never had an issue, I buy them 50 at a time
Pennies a pieceFrom the dealer? That must be costly.
