Corben Junior Ace Scratch Build.
Developed bad arthritis in my left foot a couple years ago. Dr. told me they could fix that, 2 months off my foot completely, another 2 months in a boot then undetermined time in therapy. Still hobbling about, can't afford to be out that long.
I too prefer no knives, no drugs approach. An anti inflammatory diet allows me to participate in CrossFit while limited by arthritis. I understand that sometimes that doesn’t always get it done but I get enough relief to keep on.
Special Delivery
Tom (@MrBultaco ) sent me a magazine, the 1933 edition of Flying Manual. Inside are the plans for about a dozen aircraft and engines. Yes, Virginia... actual aircraft engine plans.
Of course, Tom sent me this because it includes the plans for the Corben Jr Ace. I just loosely compared these to the plans I bought and they're the same. You could literally build the Ace off the plans inside the magazine.
I don't care what Bob (Mailman) sez about ya ( ;) ), Tom, you're a prince among men.
Cheers buddy!!
Special Delivery
Cheers buddy!!
How very timely- I'm wondering if there might be a detail in there for the Piet Sky Scout that shows the 2 steel brackets that center the fin on top the horizontal stabilizer. Mine are broken, and I'm curious if my plan to just bend 2 more out of 1/16" lawnmower deck steel is consistent with the original plans. Though it would be easier and stronger to use an off the shelf hardware store angle bracket ...
@Pat D , I've got some 301 aircraft stainless at 1/16".
I can bend you up a couple of undrilled angles... if you have the means to drill 'em to fit?
Hey, thanks a bunch, Jim- much appreciate the offer. But between Dad and me, we've probably got close to 1,000 lbs of various scrap steel and aluminum floating around, so no heroics necessary! Either making new brackets from steel on hand or using the off the shelf unit will be "challenging". Originally, I expect the fin and brackets were clamped in place on the horizontal stab, then the holes for the bolts were drilled. I have to either ensure my fabricated bracket holes line up with the existing bolt holes in the wood, or, to use the hardware bracket, drill new holes uncomfortably close to the existing ones, using dowels and glue to fill the old holes. But this is all good education and practice. I spent the weekend taking a 16 hour course that will result in me getting a LSRI(A) rating. "Light Sport Repairman Inspection Airplane". This will allow me to do the annual condition inspection and signoff on any Experimental Light Sport Airplane that I may own, but didn't build. I'll still have my A&P/IA guy do one to double check things, but I won't be grounded if he can't get to me by the due date.
The detail you posted from the plans is much less robust than what i have- my brackets are all through bolted vs. wood screws and rivets.
Dane County Regional Airport Madison WI
Look up next time you’re in the terminal. You can’t miss the full-size 1930s Corben Super Ace suspended from the lobby ceiling. Donated by the Madison chapter of the Experimental Aircraft Association, and using original 1930s plans, this aircraft stays true to every detail.
Fun fact: it’s one of just two Super Aces in the country.
Even has the Ford Model A engine conversion. :heart:
