I have a number of Milwaukee tools: Drills, rotary tool, angle grinder, hackzall, no problems with the batteries on these, then again, considering the price you shouldn't. I also have a number of cheaper cordless tools branded Ozito, or Einhell in other parts of the world. Unfortunately the batteries don't seem to last too long, they show two LEDs out of three but won't run the tool and when placed on the charger both red and green LEDs flash and the battery won't take a charge. In the past I've binned them, but, over the last few months I've checked the individual cells and found a couple of them not showing any voltage, so, I put them aside, intending on removing the duds and replacing with good cells from another battery.
Another battery went today so I stripped it and discovered two cells reading zero volts the remainder four. Before I fired up the soldering station to replace the cells, I did a little test: Hooked the two dead cells in the battery up to a 5 volt charger. When they reached 4 volts I reassembled the battery, stuck it in the drill and what do you think happened - it worked. To check, I ran the tool until the battery died then stuck it on the charger and you beaut, it charged up. Apparently the tool only flattens a couple of cells in the battery, rather than all of them, the tool won't work with a couple of dead batteries and the charger won't charge the battery when there is a discrepancy in voltage across the different cells, very odd!
I don't know if this would work with other brands, but it certainly works with Ozito batteries. Give it a try, these batteries aren't cheap.
