Custom billet inlet manifolds
United Kingdom
OK guys, I'm looking for educated comments about a project I'm considering for my current XS650 chop build, relating to making my own custom billet inlet manifolds.
As you'll know, Mike's XS make a pair that take VM34s. They have a 16mm flange and a manifold spigot that is perpendicular to this flange. Makes for easy machining. The downside is that it tilts the carbs at an angle of approx 5 degrees, due to the cyl head mating surface being this angle from vertical. I'm not sure whether VM34s tilting forward is problematic or not. All I know is that I have these manifolds on my 750 big bore 270 rephased motor and it doesn't upset performance.
So my real question is: will this 5 degree tilt upset performance if BS38s are used, as in, on my stock 650 chop engine? Yamaha compensated for this tilt in their rubber boots, so the carbs sat level. Has anyone fitted BM38s to manifolds that follow the simple profile of Mike's XS manifolds (carbs tilting forwards) and if so was it a problem?
I ask because I've modelled a handed pair of manifolds that also compensate for this tilt angle but obviously this will involve a greater amount of machining trickery to achieve the result. I'm debating whether it's actually necessary. Would prefer to just machine a set like MikesXS ones for my BS38s.
As I say, educated comments would be very welcomed.
The only thing that small degree of tilt should affect is float level, may have to adjust float height a tad.
On a side note, was perusing FB yesterday and came across a guy who fitted an XS with a dual throat side draft Weber with special manifold and had it purring like a kitten.
I have mine made, but taper them so there is no step when it meets the head, they are straight with no offset i dont use standard carbs though.
Well, thanks again for all your inputs. It's made my mind up. Going with straight manifolds, tapering internally from 38 to 34mm. Might make a few, as others seem to be looking for alternatives to the rubber boots. Ah well, onwards and upwards.
Thanks for comment. Those are pretty long manifolds. Do you have the carbs supported, other than by the manifolds?
Carbs aren't supported, I had the base made thicker to support them, I think Pipes and stuff in Wales has made some similar to what your making
If you’re machining them it’s easy to put that 5deg in the flat side of the flange that rests on the motor.
After it’s machined… then drill the holes for the mounts so they run straight.
Yes, I guess you're right, though you will end up with variable width flanges, but I suppose it won't look odd. Will CAD model it up and see. Cheers for your thoughts.
