Could you also confirm some info on the carbs....................The top caps on the carbs. Do they have writing on them like this.
Need to identify the carbs. These are 78/79 BS36 carbs...............from what i can see yours look like BS34's and they are on 80 to 84 engines.
They can be put on earlier models but also that engine may be an 80, (just don't know what a PO has done), and that is part of the reson i need a pic of the Charging system under the left side engine cover
take a pic under the round cover, that has 2 screws holding it on, it has Yamaha written on it, this is on the left side engine cover................... when sitting on the bike
Under this is your charging system. We need to see this to make sure the Reg/rect, is right and it will also help us diagnose what you have and what you need.
This is what it should look like if the factory charging system is still on the bike. Reason i want to see is if it has been changed to a PMA, (dictates what Reg/Rect you should have), and also it will help to eliminate the possibility the engine is an 80...................Posting the engine no, (on the front of the engine down by the front engine mount and it is stamped vertically), we will also be able to tell you what year the engine is
The reg/rect has 7 wires........... Yes??
3 yellow
1 blue
1 orange
1 green
1 red
If yes then this is an old one MikesXS used to sell and are now superseded
Confirm and i will post installation instructions.
Don't want to post instructions till its confirmed, in case they are wrong and confuse the situation..............Also mikesXS's instructions, (on his site), are wrong for the Points model Reg/Rect
By the way the bike looks good. Never seen a partly finished Hard tail with such a clean engine............If that is any indication then the PO was doing a good job and you may just have a good project
