De Paris
I would start with stock front and rear wheels, to make doing the brakes phenomenally easier. If I didn't like it after I was finished I would go from there. If you want rear wheel smaller than front wheel and you want spokes you might try wheels from a Heritage Special? Envoyez-moi du vin et du fromage, s'il vous plaît.
Hello
welded frame, motor mounted. I'm waiting for the wheels.
I am looking for this type of handlebars but for a classic fork.
thank you
Hello good or bad idea instead of the regulator?
No response from hugs, so I'm making
Good morning all here I made my electric power supply plan. I don't know if this is fair. I have a rick's regulator which I do not understand everything ...? Thanks for your help
Hello
which seat do you have comfortable?
thank you
Well, if comfort is a priority, a hardtail may not be the best starting point. But a sprung solo seat may be a bit more comfy than a non-sprung. I assume you want a slim look, so that rules out thick foam. Also, the shape of the seat becomes more important when using a low profile seat.
Good morning all
my new plan.
I don't understand why Revival puts a relay here.
The box on the left is switching a line on the CDI between ground and open, to turn it on and off I assume. I haven't read what you have already but all that stuff is probably not be the easiest way to get an ignition going.
Good morning all seat and handlebars arrival. I'm waiting for my wheels
