From the factory manual -
Yet another rabbit hole to get lost in the weeds on. Has anyone ever actually measured their dipstick markings, like in the manual picture? I have. I think that picture is wrong.
I contend that:
The early dipsticks had a higher "high" mark.
The lower mark never moved.
The 140mm measurement in the pic is correct for later dipsticks.
The 25mm measurement is wrong. It does not refer to the distance between the marks an a later dipstick, nor does it refer to the distance from the low mark to the end on the stick on any year dipstick.
However, 25mm IS the measurement between the marks on an early dipstick.
And on an early dipstick, the measurement to the first mark is 130mm, not 140mm. That's the 10mm difference the factory manual cites.
In other words, in that manual picture, they have conflated the two dipsticks. The 140mm measurement is from a later dipstick, and the 25mm is from an early dipstick.
Rambling on: I think the consensus is that they lowered the high mark because too much oil was being blown out the crankcase breather. And, that's why they actually recommend that you use the dotted line mark, halfway between high and low on a later dipstick. To lessen the oil being blown out the breather.
