gusto
It seems like the last person didn't use sealer on case or on head. Is it ok to use no sealer. These case halfs were on together real tight without it. I got some sealer but don't know if I should be using it.
This is probably the best answer.Permatex Grey, Yama Bond, Honda Bond, Basically any grey ##### Bond is it
It’s grey.yamahonakawasuzi #4 is safe VOC wise
#5 is good stuff sets up stiffer for a more ridged crankcase(stressed member)
1184 I've never used
From years of building VW motors, I prefer using Permatex Aviation Form-A-Gask #3. Cool part about using it, if the case seal or anything is a tight tolerance, when you pull the parts apart, I have found the Permatex never hardened. Easy to clean up with brake cleaner BTW.It seems like the last person didn't use sealer on case or on head. Is it ok to use no sealer. These case halfs were on together real tight without it. I got some sealer but don't know if I should be using it.
That's my go to as well. VW's, Corvairs... bikes, Lycomings and Continentals.From years of building VW motors, I prefer using Permatex Aviation....
