@Jim you are 100% correct that EVs are the future. The thing is they are the future not today.
Without doing and working on the future today, then today will never work towards the future.........Everything done in increments work towards that change.
Stating its a waste of time, it is not economic or it crates more pollution at present, only inhibits the change that is required to make all those things it work in the future..........A short time loss will be offset by the bigger change, the faster the change the shorter time loss becomes negligible........
. Some of the charging stations in place now use diesel powered generators that burn more fuel to charge the vehicle than the same amount of fuel would power the vehicle even farther.
In these situations they are a stop gap measure between Charging stations, to get the car to the next EV charging station............so the loss is absorbed by the overall distance the car travels, Just makes ita little less efficent overall, but not when campared to a combustion engine Vehicle. If the case is, the EV can only be charged by a Diesel generator then the argument would be valid............
Catch 22............If we don't make EV's there will never be the demand for the infrastructure to cater for them so it will never be built.
If we build EV's, the infrastructure needed to power them will always lag behind till it doesn't, because the demand for the Infrastructure is driven by the amount of EV's produced...............
Kevin Costner proved it......................
