yellowdog
yellowdog
Morning all,I thought it was too good to be true with my rebuild xs2.
Got it all back together engine great, stopped the fuel taps leaking, brakes ok. But no lights ,nothing . annoyingly they worked previously so it must be something I've done .
I've got no brake light or rear lamp no headlights all I've got is a neutral light and the horn.Surely brake lights should work independently of lights ? Could it be the switch isn't grounding?
I took the light switch apart to check it and then the fuse blew since then nothing works could I have blown something else ,rectifer regulator or some other component? I'm useless with electrics haven't got a clue .I suspect the switch but I don't know .These early switches are grounded at the switch by a small tap that touches the handlebars so maybe not the ground ,Sorry to go on but need some advice please
