from ali-express
this is closest size, should only need the ID enlarged and a slot so it conforms to the tube ID
15 x 25 x 3mm
2mm 3mm Thick PTFE Sealing Ring ID 3mm-66mm PTFE O-ring Gaskets OD 8mm-75mm
Feature:
• Used for faucet pipe, hose bolt, valve, or other gardening maintenance or retrofit
• It can prevent the pipe from leaking and provide positive shut off, stop leaks to save energy
• Durable PTFE with wear-resisting, anti-corrosion, strong sealing, and can be insulated
• Hard material, high strength, not easy to damage, not easy to aging;
• Suitable for the temperature of -180℃-300℃ in a variety of corrosive media as gasket seal and lubrication seal, and in a variety of frequency use of electrical insulation materials.
Specification:
• Material: PTFE
• Temperature resistance: -180℃-300℃
• Color: White / Transparent
• Inner diameter: 3mm-66mm
• Outer diameter: 8mm-75mm
• Thicknesses: 2mm 3mm
The package includes: you choose. Select your requirement from the drop-down menu above.
15 x 25 x 3mm
Description
Report Item / Suspicious Activity2mm 3mm Thick PTFE Sealing Ring ID 3mm-66mm PTFE O-ring Gaskets OD 8mm-75mm
Feature:
Specification:
• Material: PTFE
