Engine removal.
This is the way I did it the first time. Subsequently, I used 2 long pipe lengths and did similar to 5Twins which I prefer now.
Glenn
I am planning to pull my engine soon.
I have 2 boys that still live in the house to help removing and replacing engine so I will do the 2 pole stretcher method.
For connecting the engine to the poles, any simple ideas as I don't plan to weld anything.
I could drill through the pipe and make eyelets to go to bolts though or connect w/ chains from eyelets to engine.
I wrap the frame with rubber strips from old cut up inner tubes to keep from scratching it. My original removal/install "tool" was just a couple of "handles" that connected to the engine. With a helper, we could lift the engine like a stretcher and wiggle it in and out of the frame. This worked well but you need two people .....
Eventually, I built myself a one-man removal/install "cart". It's based on an old shopping cart I pulled from a ditch on the side of the road out in the country, one of these smaller types .....
It's all man-powered, no hydraulics, just using simple leverage to lift the motor. The lift handles I previously made slip on the lift bars and act as extensions to give the needed leverage .....
Both ends of the pivot bar can be adjusted up/down to get the perfect height .....
Simple hooks made from 1/4" bar stock hook under the cart handle to hold the motor lifted as you roll the cart in .....
It works quite well ......
Strong boys? The stretcher is unnecessary. The boys can easily pull the engine out the right side. Simple!
One weight lifts and the other has already developed a "dad bod".
I have a recovering sprained left hand so I'm about 25% strength on the left side.
I'm ok with stretcher as I have the pipes already from work.
Yes, eye bolts through the pipe would probably work just fine. You might want to wrap some rubber around the front one as it contacts the front of the motor when you lift.
just use 1" ratchet strap with or without the ratchet block. Wrap tightly, tie or ratchet out the slack. Plenty strong, takes up little room, won't scratch paint.
Old man's lift.
This is the way...work smarter, not harder.
I had a slip and fall accident several years ago, broke my back and severely whiplashed my neck.
I cant lift anything without being in neck and shoulder pain for days afterwards (even 5 gallons of gas will do it!!). So now when I need to lift engines I use an electric harbor freight winch attached to underside of my loft with appropriate straps/chains. That way I can do it in controlled baby steps...works a charm every time. 👍
Yes I think one is enough
I don't have particularly strong arms . I Made a small stool ..of 2 x 4 planks Nailing it together the right height having beside the bike
A little higher than the frame tube
Holding my chest against the upper frame tube saving the back -- one arm on each side -- and then lift with the arms Step by step getting it out on the stool. Can have some protection on the tube if one wish I don't
Keeping it simple -Works for me there are good places to grip the engine.
I've done 20 or more, exactly that way!
To lift the engine out, I use a cheap Chinese block and chain:
which I hang from a Z1 fork leg placed over two rafters. Bike on side-stand, tie-straps (I use old Judo belts) wrapped around and under the engine, engine bolts out, lift slightly and ease out to the right. The mechanical advantage the block gives makes it an easy lift and you can move it in small increments to lift out past the engine mounts.
I did not post how I did my engine pull back in late 2023 (gosh that seems like it was not so long ago, time flies)
I don't regularly pull engines so did not want to invest in much. I have 2 pipes I used and got a TCBros XS650 engine stand that I mounted onto my old portable work mate. Minimal investment here did the trick.
Of course, I have a motorcycle lift and strapped the center stand to front wheel to keep it from moving.
2 of my sons did the lifting (one on each side of the bike) to move to the engine lift, then roll over to the table and lift onto the engine stand.
Pipes just strapped to the poles.
This makes it a minimum 2 person job (3 people and its even easier to negotiate the lower bolts into the engine stand and then later the frame when putting it back in) though but minimizes setup and cost.
