buzzword
Buzz, loving your work on this bike. I'm interested in your braided nylon tubing you used for your wiring. I have been eyeing some materials like this for my upcoming re-wire. Can you post any pics of your wiring or product review where you got it from? I know you mentioned it was a real pain to install. Any tips to make this easier?
Thanks! I appreciate the kind words.
I used a couple different braided wire sheaths
- Got this Flexo Clean Cut stuff at wirecare.com -- seems pretty durable, but actually frayed pretty badly and required a great deal of care to install cleanly. Looks great once it's done though!
- I also used this black PET sleeving stuff from cableorganizer.com. It didn't fray as much, and expanded pretty well in order to make installation somewhat easier.
As far as it being a pain to install, my answer is yes - really because it's just super tedious. The stuff expands pretty well in order to slip wires through it, but once you heat the end to reduce fraying during install, that end becomes less flexible and you end up fraying the ends anyway. Luckily, standard practice is to put heat shrink over the ends in order to prevent the sleeve from migrating, as well as to stop the fraying. It's hard to heat up the end of the sleeve once wires are installed for obvious reasons!
A couple tips:
- Start by sticking the wire (or bundle thereof) into the sleeve as far as you can push it before the sleeve starts to resist you, then pinch the end of the wire(s) that you've already pushed through the sleeve. While holding them in place, squeeze the sleeve further down and push the sleeve up the wire(s), which sorta balloons the sleeve. Think: sausage casing - dunno how else to describe it. Once you've got a good "balloon" of sleeve, let go with your first pinch, keep holding onto your second, and the sleeve should rapidly contract and therefore shoot further up the wire(s). Repeat this until you get to the end of the sleeve, or the end of the wires.
- I strongly suggest using adhesive-lined heat shrink tubing, as it stays in place WAY better and doesn't let the sleeve slide up and down your wire(s) -- this is crucial, actually!
Hope this helps!
